Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 24 5:06 pm)
If I remember right, the new mannequin is a .pp2 (prop) file. The Tailor defaults to loading character files. You need to change the file type box on the load screen to "All file types". You should then be able to find and load the mannequin. Don't forget to select the full body morph for conversion.
Attached Link: http://arcana.daz3d.com/index.php?id=46
Go to the attached link. This is the tutorial for converting V2 clothing to V3 at DAZ. The downlinks for the mannequin and the pose set file are included. I hope this helps. Be warned, sometimes it takes awhile for the conversion and it doesn't always work quite the way you expect it to. On the other hand, it works most of the time and it is nice (and cheaper) to use some of the old V2 clothing items on your V3.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
A while back I posted in the Poser folder to create a M2 to M3 mannequin. At the risk of sounding stooopid, I've followed the instructions posted back then (original post: http://www.renderosity.com/messages.ez?Form.ShowMessage=1437583) But when I import the mannequin the Tailor doesn't like it and won't load it. I was able to follow the instructions to create the V3 to V2 mannequin and that worked perfect. What am I doing wrong?!
