If you mean the *.xml files - I belieeve they're all text files - any editor like wordpad or notepad that saves unformatted text will work. I used Wordpad to edit LibraryPrefs.xml myself. When in doubt, copy off a dupe of any files you edit to a backup subfolder first so you can restore easily in case of any problems.
leather-guy, I do mean the *.xml files. I installed the SR4 and now it wants to eliminate my pngs in categories with more than 100 choices. I've tried Wordpad, but it has not worked. I am thinking I need to save as an xml file, but it does not give me that option. Any help will be greatly appreciated. Thanks.
Poser 5RuntimeprefsLibraryPrefs.xml its like the fourth line. it says LibraryPreferences curFolder="1" previewNum="100" Change the previewNumber.
My Homepage - Free stuff and Galleries
use notepad and just hit save when your done. there is nothing special about an xml except the way you spell the extention :)
browse to the direcory right click on LibraryPrefs.xml go to "open with" and choose notepad. make the changes. go to file and save exit out of notepad right click on LibraryPrefs.xml go to "open with" and choose notepad. if it is still 100, i suspect your computer is possesed by an evil spirit and you should seek help from clergy. :)
from what i can tell, it servers two purposes. 1. when you return to a library it will take you back to the folder you were in last. 2. it drives paranoid people nuts.
Need to edit preference file, P5 SR4. What do I open the file with to edit? What do I save as? Thanks in advance for help.
