Mon, Jan 27, 3:10 PM CST
Subject: Labyrinth
mike3d ( ) posted Fri, 05 March 2004 at 1:14 PM · edited Mon, 27 January 2025 at 3:09 PM
Does one have or know a good Bryce Labyrinth which I could download?
tjohn ( ) posted Fri, 05 March 2004 at 1:42 PM
If you have a paint program you can make one of your own. Here is a simple black and white height map I made in Photoshop Elements.
rickymaveety ( ) posted Fri, 05 March 2004 at 1:43 PM
No, but a good labyrinth would only take a few minutes to make in a 2D program, then you would just use the 2D image to create a terrain with your labyrinth. Do you want someone to cook one up for you, or do it yourself??
Could be worse, could be raining.
tjohn ( ) posted Fri, 05 March 2004 at 1:48 PM
Create a terrain and go into the terrain editor. Raise the resolution of the terrain as high as you want. Load the height map as a picture into both picture slots. Hit apply. Go to elevation menu and hit smoothing twice. Clip the bottom (or just lower below ground a little). Go to render screen and drop terrain to ground. Adjust the height and size of terrain to taste. Here's a textured version of the height map above. Hope this helps. I or others can help you with details if you want to try this method.
tjohn ( ) posted Fri, 05 March 2004 at 1:49 PM
Hey, Ricky, if you don't want to help, at least get out of the way, LOL!
pogmahone ( ) posted Fri, 05 March 2004 at 1:49 PM
Here's a good link that gives examples and construction methods for all sorts of labyrinths http://www.labyrinthsociety.org/
rickymaveety ( ) posted Fri, 05 March 2004 at 1:52 PM
I was just about to post one. So there.
tjohn ( ) posted Fri, 05 March 2004 at 1:53 PM
Yeah, go ahead, make my map look dinky. :^)
rickymaveety ( ) posted Fri, 05 March 2004 at 2:28 PM
*snicker* Plenty of good images on google ... just search under "maze"
Quest ( ) posted Fri, 05 March 2004 at 3:07 PM
ROFL!
danamo ( ) posted Fri, 05 March 2004 at 3:36 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=587332&Start=1&Sectionid=2&filter_genre_id=0&WhatsNe
I would also like to point out electroglyph's recent gallery posting, a maze made by innovative use of a scanner and the Sunday newspaper puzzle page. Excellent way to generate a complex heightmap in this case.
diolma ( ) posted Fri, 05 March 2004 at 5:13 PM
Drat! Now I got lost! Someone help me get out of here???? Cheers, Diolma
electroglyph ( ) posted Fri, 05 March 2004 at 6:29 PM
Here's another clue for you mike. you can set up a terrain in the terrain editor. If you apply the maze image in the second window of the editor you can make the walls follow the terrain you built. Actually the image is from one of the little maze books in the grocery checkout, about 98 cents.
Zhann ( ) posted Fri, 05 March 2004 at 7:18 PM
Very cool, I have a maze book somewhere, hmmmmm....
Bryce Forum Coordinator....
TheBryster ( ) posted Fri, 05 March 2004 at 8:56 PM
Now we just need David Bowie and we're all set.... The power of the Babe!
rickymaveety ( ) posted Fri, 05 March 2004 at 9:03 PM
David Bowie, Jennifer Connelly and a worm!! (Come inside, meet the missus!!)
TheBryster ( ) posted Fri, 05 March 2004 at 9:05 PM
Don't go that way! Never go that way! Leads you right up to that horrible castle....!
ysvry ( ) posted Fri, 05 March 2004 at 9:48 PM
plz no bowie. i heard he lifed around the conner here lol
for some free stuff i made
and for almost daily fotos
Rayraz ( ) posted Sat, 06 March 2004 at 4:35 AM
I remember making a digital labyrinth once for school... I'll see if I've still got it :)
(_/)
Zhann ( ) posted Sat, 06 March 2004 at 6:11 AM
Diaper* ornament works well as a maze too...found this from one of my old design classes...
*Diaper ornament; type of ornamentation where a major element repeats at regular intervals forming an interlocking pattern...
Zhann ( ) posted Sat, 06 March 2004 at 6:12 AM
For those curious about the texture I used, it's called fossiliferous...
TheBryster ( ) posted Sat, 06 March 2004 at 6:47 AM
For a moment I thought Jan was talking about nappies...!
Zhann ( ) posted Sat, 06 March 2004 at 8:22 PM
;P
SevenOfEleven ( ) posted Sun, 07 March 2004 at 11:43 AM
That fossiliferous texture looks interesting, where can I get it? If you have the mac program called artmatic pro, you might be able to make some great mazes. You may have to make the gaps yourself.
Zhann ( ) posted Sun, 07 March 2004 at 7:13 PM
It's in my Bryce mats package in the RMP...:)
SevenOfEleven ( ) posted Sun, 07 March 2004 at 9:02 PM
RMP?
Zhann ( ) posted Sun, 07 March 2004 at 11:16 PM
Renderosity Market Place
