You are right... It does work when removing another cube from insde the larger one. However, my problem was created by a complex 3D model of a building I was using the inside of. Extruding a cube or even a smaller version of the building itself didn't help. I guess I will have to figure out another model to use instead. Thanks
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1632807
This theme were already threated at the link above.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
![file_101499.jpg](https://live.cdn.renderosity.com/forum/threads/1696108/file_101499.jpg)
I can't remember if that one has been discussed yet or not. I am running into an issue of Vue (both Vue 4.2 and Vue Pro) turning lights inside an object into shades of blue. If you take any atmosphere, remove ambiant lights (lighting from sun and from sky only) and create a simple scene of a camera inside a cube with a simple light, you will see what I mean. Is there any way to remove that blue effect when the camera is inside an object ?
