Mon, Dec 2, 4:50 PM CST
Subject: Using .ter files
flmmkrelabs ( ) posted Mon, 08 March 2004 at 3:34 AM · edited Mon, 02 December 2024 at 4:50 PM
I have noticed many files available in the Bryce downloads section that contain .ter files, yet I cannot figure out how to use the in Bryce5. Any help is appreciated
gillbrooks ( ) posted Mon, 08 March 2004 at 4:16 AM
.ter files are for using with Terragen (free). To use them with Bryce you have to load them in Terragen then export them as .bmps - you need the FEO plugin to do this(unless there's another way of doing it that I don't know about)
Gill
dan whiteside ( ) posted Mon, 08 March 2004 at 6:52 AM
I'm using the Mac version of Terragen and under Export there's also a Lightwave export (LWO) which Bryce reads through the File/Import Object... item. Not sure about the PC version. Best; Dan
gillbrooks ( ) posted Mon, 08 March 2004 at 6:55 AM
I've used the lwo export to use in Bryce but if you do that you can't edit the terrain as you can if you export a bmp then create the terrain in TE But then, it's all down to personal prefs :-)
Gill
wildman2 ( ) posted Mon, 08 March 2004 at 1:00 PM
use the firmament plugin and export as a raw convert to pgm in psp or bmp.if you made a color map for the terrain there are settings that will set the camera dead center from the top to make a render
"Reinstall Windows" is NOT a troubleshooting step.
