Sat, Jan 25, 6:23 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Weird Aura Effect
biggert ( ) posted Fri, 05 March 2004 at 7:16 PM · edited Sat, 18 January 2025 at 4:43 PM
hi all....i got another problem in carrara 2.1 when i apply the aura effect to the scene below i get these jagged edges....the anti-aliasing is set to Best...when i turn the aura off the pic renders fine the object below is just made of 3 lofted polygons that were exploded.... clouds were added and rendered with hybrid raytracer with soft shadows... is this a bug or am i missing some setting? please help...thanks for any tips. =)
biggert ( ) posted Fri, 05 March 2004 at 7:19 PM
heres the render with the aura disabled
Kixum ( ) posted Fri, 05 March 2004 at 8:14 PM
Do you have the distance attenuation turned on in the 3D aura? -Kix
-Kix
TOXE ( ) posted Sat, 06 March 2004 at 1:58 AM
I agree with Kix, it seems that you have DA turned off. TOXE
biggert ( ) posted Sat, 06 March 2004 at 3:01 AM
thanks for the advice guys....i tried turning on DA and leaving it at default setting 16.....no effect...the object still ended up looking jagged like the first pic above... i tried the aura with a simpler object....i used the sphere primitive and exploded it...turned on DA to 16, anti alias at best, and soft shadows...it looks like the jaggies are there again but its hard to see what they look like though cause of the aura....but you can clearly see black spots/creases though.... any more suggestions? thanks again for the help...much appreciated.
TOXE ( ) posted Sat, 06 March 2004 at 3:40 AM
You can try to: -set the filter sharpness to 0 -add a value of 1 in the blur object effect hmm, no other ideas at the moment, let me know if this help... TOXE
ShawnDriscoll ( ) posted Sat, 06 March 2004 at 1:15 PM
Cast Shadows turned off?
Kixum ( ) posted Sat, 06 March 2004 at 5:52 PM
And turn your object accuracy in the render room to 0.5 pixel. -Kix
-Kix
biggert ( ) posted Sat, 06 March 2004 at 7:53 PM
thanks for following up guys! much appreciated. =) TOXE: i havent tried your suggestion yet...i just recently started playing with C 2.1 (even though ive had it for 8 months now and $300 bucks lighter in the checking account) SHOONER: i tried turning off the cast shadow for just the object but still the same.... Kixum: ill try your advice.... ...ill report back...... thanks again for the tips! =)
mdesmarais ( ) posted Mon, 08 March 2004 at 8:26 AM
Wasn't there a problem with the post effects not being anti-aliased correctly until C3? Light cones is what I am thinking about, but maybe it would be applicable to aura as well.... Markd
ShawnDriscoll ( ) posted Mon, 08 March 2004 at 6:28 PM
How about setting transparent objects to allow light through when rendering? Is that turned on or off?
biggert ( ) posted Tue, 09 March 2004 at 6:28 PM
thanks again for follwing up... will try that
