Do you have an accidental extra pair of eyeballs? Looks like an overlap of nearly-identical surfaces.
My python page
My ShareCG freebies
With two characters, crosstalk could be an issue. Koshini/Ichiro are horrible about this, even when you use a Null. Also, I noticed that sometimes when I load a PZ3 up, it will pull in the wrong texture of the same name (such as blue.jpg for some blue eyes, but bring in blue.jpg for a reflection, from a diff directory.)
You have to add the NULL in the beginning Before the other characters. And then be sure to select the NULL again before adding each character. I find they usually work, but sometimes don't. In last ditch effort you may try loading one of the characters into MorphManager and rename all the morph zones. BE SURE to save under a DIFFERENT NAME so you don't loose your original!!!
