Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 11:58 am)
Attached Link: http://www.rbtwhiz.com
Bloodsong has a universal (biped) null at www.3dmenagerie.com (in Downloads) and Rob Whizant has a Millennium null at www.rbtwhiz.com (click Downloads, first dot to right of the digital-readout thingie, then the link is bottom right of the main window).Its something like an invisible Vicki. I got it from Daz and its called 'Millennium Null', it still should be there and its free. You put it into the library like a real model. Then you load it like a real model and activate a special bodypart 'Body:1'. Its supposed to distract the crossing-informations to itself so the second Vic should come like you made her. Maybe Im using it in the wrong way, with V3 it never worked for me. Ill try it like RHaseltine said, till now I loaded the first Vic, then Null and then the second Vic.
I am having an odd problem when I load a 2nd figure into my project. The first thing I noticed was that the eyeballs on the 2nd figure were "bulging" out and I had to adjust them on the z axis. Then today, I modified V3 with all the male/masculine morphs and saved the figure. When I loaded the figure into a scene that already contained a figure, not only where the eyes bulging again (creepy), but none of the morphs were in effect even though all the dials were there and were set properly. When I cleared the project and loaded the problem figure FIRST, it showed up correctly. This has happened only with V3 characters that I have altered myself, but not with characters I have purchased. Is this a memory issue? I am running P4 on a Mac. Any thoughts? Thanks!
