Thu, Nov 28, 5:51 PM CST
Subject: Texture question for Zhann or anyone with an idea
catlin_mc ( ) posted Tue, 09 March 2004 at 9:39 AM · edited Thu, 28 November 2024 at 3:40 PM
I've got two phototextures I've been trying to add together in Bryce and to some extent it's working but the color seems to be fading with altitude and I can't figure out why. Here's a pic of the applied material and my settings, so if anyone can see where the problem might be please let me know. Cheers 8) Catlin
draculaz ( ) posted Tue, 09 March 2004 at 10:08 AM
hmm... have you tried doing it in pre-work? as in matching them together and then loading the new one in bryce? m
diolma ( ) posted Tue, 09 March 2004 at 10:26 AM
Catlin, when you use "Mode AB" (ie, textures in A and B), the two textures are blened together basd on altitude. Tex A appears at the top, tex B at the bottom - just like you have there. This behaviour is built into Bryce, and I don't know how to change it (at least, not in .1, which is what I have - maybe there are methods in later releases). Try using "ABC" mode. In that mode, A and B are blended based on the alpha channel of C. So all you need for C is a simple mid-grey pic, and you should get even blend all the way.. (btw - I don't know how things combine in "ABCD" mode - it's not covered in my manual..) Cheers, Diolma
Aldaron ( ) posted Tue, 09 March 2004 at 10:28 AM
You are doing an AB blend which blends the 2 textures as altitude goes up but is based on the tallest object in the scene. To fix it try adding a C channel with the alpha all mid range grey (128,128,128) and it should blend evenly. With ABC blend the alpha channel of C etermines how textures A and B are blended.
diolma ( ) posted Tue, 09 March 2004 at 10:29 AM
oops. "blened" = "blended"; ".1" = "3.1". (I was typing 1-handed with manual open on my knee. My excuse and I'm sticking to it.) ;-)
Cross-post!
Aldaron ( ) posted Tue, 09 March 2004 at 10:30 AM
LOL cross posted with diolma as I was checking out that a grey alpha would work :)
catlin_mc ( ) posted Tue, 09 March 2004 at 11:30 AM
Thanks guys I knew it had to be something simple. This is the first time I've had this problem even though I've mixed pics before, but I have not written down my settings from previous attempts which is why I got this problem. I've now re-downloaded Zhann's work sheets to keep a record so I won't forget in future. Cheers 8) Catlin
PerryMcK ( ) posted Tue, 09 March 2004 at 3:25 PM
Zhann's worksheets? Mike
Flak ( ) posted Tue, 09 March 2004 at 6:11 PM
Attached Link: Zhann's Freebies
http://www.renderosity.com/freestuff.ez?Form.Contrib=Zhann&Topsectionid=0
Digital WasteLanD
jedswindells ( ) posted Tue, 09 March 2004 at 7:28 PM
Just blend them in PSP or simmilar,then you've halved your work from the start.
catlin_mc ( ) posted Wed, 10 March 2004 at 5:36 AM
jedswindells I did that too but it's always much simpler if you can get it to work in Bryce 'cos then you can continue changing the results. 8) Catlin
