(Last Updated: 2024 Aug 27 11:07 am)
I use Meta quite a bit, but haven't any experience of working with .X files (that's Direct X right?). But I generally use another application for putting textures on models. There's a good, free (but unsupported) one called Lithunwrap which may be still around somewhere on the web, but its originator now has a commercial (but inexpensive) improved version called Ultimate Unwrap. You can load/save your models in a variety of formats with both of these as well. I'm just guessing now, but it may be that Meta can't save the UV co-ordinates to certain file formats, and that one of those is .X That would make your textures disappear (but not colours..hmmm...don't know then). Best get a UV mapper; that would probably be the quickest solution :) Hope this helps.. Mick
thanks Mick for the sugestion, I'll try it but I'd rather figure out why Metasequoia Le just started doing this. It could be that may AOL art file is corupt again. It messed with my cg files and programs last time but I hate to uninstall purg the aol file and reinstall my programs. I don't know but I'll poke and prod till I figure it out. Wish I could regster Metasequoia 2.3, its a better program, but it seems that it can only be regestered in japan.
It's more than likely that the problem isn't with Meta. I've always found it to be entirely bug-free and very stable. If this is something that's just started happening it is most likely the aol file, I would think. It's true it can only be registered there, but that appears to be mainly because Mizno's site doesn't have any means of online purchase. Also I guess he doesn't want the hassle of having to produce documentation in other languages for international sales. I suppose that if you knew somebody in Japan who could pay there, you could register it. Mick.
Ya. That fixed it. Had to delete MetaLe, purge my AOL art file, then reinstall MetaLe. Third time, getting old. Sence I'd like to show off my planes , and it seems that the best FMS sights are in eather japan or germany, I'm going to see if I can't make some contacts there. I much prfere to work with Metasequoia 2.3 so that my be my only otion to get it regestered.
Been using Metasequoia for a couple of weeks. I use 2.3 for modeling and Le for creating .x files for FMS. Thats how I got here I model WWI planes and couldn't live with the inacuracies of the models. Lately metasequoia Le has been stripping the textures and colors off of the planes that I've done on it and 2.3 when I load them to create .X files. Any body got a clue? Some how I've gotten more into 3d cg then flying model planes. Most of what I use is freeware. So after a seven hour done load of Maya; the free version, all I have to say is omfg.
