Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Oh you sneaky little devil you! Excellent solution to a problem that we've needed for a long time. I'm assuming this only really works for a plan (or an object that it's actual edge doesn't appear in the scene). Is it possible to blur the plane into the objects sitting on it causing a problem? Regardless of my ?'s, it's an excellent tip! -Kix
-Kix
-Kix
![file_101815.jpg](https://live.cdn.renderosity.com/forum/threads/1699611/file_101815.jpg)
Hi guys, Today i've discovered a little simple method to create simply blurred reflections. Unfortunately it works only with a plane. Simply apply the Blur Object function to a plane, it seems that gaussian drop off function works better than the other method. I hope you find it interesting and useful. -TOXE
