Wed, Jan 15, 12:41 AM CST
Subject: Boolean
deacali ( ) posted Fri, 12 March 2004 at 5:27 AM · edited Mon, 04 November 2024 at 10:58 PM
How can I apply boolean operations to obj files imported into Bryce from Poser?
Zhann ( ) posted Fri, 12 March 2004 at 6:27 AM
I suspect the same way you would for any Bryce object, select an object make it positive, select the one you want to cut with , make it negative and group them...if that's wrong, I'm sure someone will correct me
Bryce Forum Coordinator....
hutchingsm ( ) posted Fri, 12 March 2004 at 6:45 AM
You have to 'Edit' the object and make it 'Solid When Boolean Rendering'.
pauljs75 ( ) posted Fri, 12 March 2004 at 5:04 PM
Also note that on some objects the solid setting may affect how internal normals are rendered. Some meshes with holes in them, normal backsides may disappear if set to solid. (At least it does in Bryce 4.)
Barbequed Pixels?
