Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
As for sharing it, i'd love to! just not sure how to go about it. Kev, As nobody's answered your question, I'll give it a shot. Within Poser select the Head then do a copy (Ctrl-C) and then paste (Ctrl-P) into any text editor. Repeat for the Body if applicable. This will capture all the parameter dial values. Afterwards you can edit the text file to remove everything but the parameter names and values (as for example Grey Cat does). Or you can leave as is. In fact if you leave as is it's even easier for the person applying them to V3, they can simply reverse the process (Ctrl-C from text file, Ctrl-P into fully injected Poser V3 figure) - no dial twisting for them to do at all. (If you run Daz's IPB first on the saved character that will hide the 0-value parameters, else you could just edit those lines out of the text file afterwards, or if going the "as is" route, just leave them in there.) Then go to Gallery here, select Poser and Character Formulae, post your picture, and paste the text file underneath - see many examples by Grey Cat.
. ( <--- that's a bookmark in case this thread remains active)
