Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 3:20 pm)
That particular update that I took the plunge on kind of upset my Poser methods... Ever since the update I can't change the background color, and I have to watch how close to the edges my models are because it'll cut off about 100 pixels of it on each side in the final render....... Just little things that are driving me nuts!...
Can't change background color... Your preferred state is probably corrupted. Set poser to launch to factory state, exit and repoen. Then position your windows back where you like them and resave your preferred state. Probably better delete all the UI dots too. 100 PX cut off? Not doing that for me. What's the setup where you see this? Nerd
I'll try that. I figure I would block off some time when my finals are over to fix it...But thanks for soemthing to try in the mean time... I usually set my renders to 2400x2600 300 dpi...When I do the final render...I'll find that about 100 pixels on each side were cut off from the Poser file I'm rendering. I usually just have to zoom in on the camera so that all of it will render.
The readme for the SR4 updater said something about the background color getting stuck and how to unstick it. (some problem with a node) There are 3-4 posts on this, check for links. I'm not sure if it was caught with the 4.1 update, but it just takes a second to do a couple of deletes and things work normally again.
I am going to take the plunge and update my P5. Do I install both of these or just one. Thanks for your help. I know there were some issues soI would like to do this correctly. cheerio lululee Poser 5 - Service Release 4.1 Application Updater or (Poser5-SR4.zip 22.58 MB)
