Mon, Feb 10, 1:53 AM CST
Subject: What does a Mac user do with pcf?
Barbarellany ( ) posted Tue, 23 March 2004 at 4:02 PM ยท edited Mon, 10 February 2025 at 1:30 AM
I downloaded something that has a pcf file. I have the seed fire but obj mover is not for mac. What do I do?
Estruch ( ) posted Tue, 23 March 2004 at 4:20 PM
Attached Link: http://www.soft-rabbit.com/
Use Maconverter.
Ajax ( ) posted Tue, 23 March 2004 at 5:17 PM
Does Mac converter handle pcf? I thought pcf files were pretty much off limits for Mac users.
dbutenhof ( ) posted Tue, 23 March 2004 at 5:56 PM
It works with most, anyway, though I've heard suggestions it doesn't work with all. What it doesn't do is RTE. But RTEJava takes care of that. Of course it'd be nice to have them combined; along with something that can fix those old rsr files without running Classic. With Poser 5, those 3 functions are all that's needed.
Triarius ( ) posted Tue, 23 March 2004 at 6:55 PM
What is RTEJava?
Ajax ( ) posted Tue, 23 March 2004 at 7:39 PM
RTE is an encoding system used to distribute modified versions of copyright protected mesh - ie it does the same thing as pcf, just in a different format. I haven't heard of RTEjava before but I assume it's a version of the RTE software written in the programming language, java, which is platform independent - so you can run it as easily on a Mac as on a PC Still no help for decoding a pcf file on a Mac though.
dbutenhof ( ) posted Tue, 23 March 2004 at 8:03 PM
RTEJava was written this year by Mark Davis. I suspect it's in Freestuff; but you can also get it at http://www.geocities.com/RTEJava/alpha/
It works well, with the advantage that you should be able to run it anywhere with a Java implementation.
Barbarellany ( ) posted Tue, 23 March 2004 at 9:37 PM
Maconverter worked. Thanks so much.
