What was the Morph suppose to do Originally? I have done many morphs with Z Brush with no Ill effect.. http://www.3dcommune.com/3d/store/more_info.mv?P1074333664 Maybe you try to have the morph do to much? If you want to change the whole face.First do one for the chin then another for the brow then another for the cheeks and so on....Don't do one to change the whole face at once..
Attached Link: http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=009969
That is the infamous "face reversal" problem that is inherent in ZBrush. What happens is that the morph flips the points from one side to the other. There are a few ways around it ... (1) ZBrush has a script that fixes the problem. See the attached thread for more info. (2) You can re-import the morphed head back into ZBrush and then resave it again. That will save the morph you already did. Or (3) To get around using the script, and for doing multiple morphs of the same body part (such as the head), import the body part into ZBrush and save out the "reversed" head BEFORE you do any morphs. Then import the reversed head for any morphs that you do later on.Thanks, Deecey :o) That sounds like an easy fix... If I can find that button to import again L How can ANYBODY find their way around that interface?! O.o
There is a Z script for free downlaod that exports the obj's properly. Just reimport obj and export again and it will flip it back.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
