Mon, Jan 27, 5:31 AM CST
Subject: Z-brush "flattens" my morphs
TrekkieGrrrl ( ) posted Thu, 25 March 2004 at 7:28 AM · edited Sun, 26 January 2025 at 1:06 PM
Sooo I had an opportunity to play with z-brush. Since it's a new program for me, I MAY be doing something wrong, coz this is what happens: The head of the character is inverted. And not JUST inverted vertices. It x-flattens the head at a setting of 0.5 then when the morph is applied at 1 it is inside out :o( Is that normal for Z-brush or have I messed up? I was told it was good for Poser Morphs.. now I don't know what to say *LOL*
artistheat ( ) posted Thu, 25 March 2004 at 8:08 AM
What was the Morph suppose to do Originally? I have done many morphs with Z Brush with no Ill effect.. http://www.3dcommune.com/3d/store/more_info.mv?P1074333664 Maybe you try to have the morph do to much? If you want to change the whole face.First do one for the chin then another for the brow then another for the cheeks and so on....Don't do one to change the whole face at once..
TrekkieGrrrl ( ) posted Thu, 25 March 2004 at 8:42 AM
Ah my post DID eventually post.. here's the rest then: Here's the morph at 1.0
TrekkieGrrrl ( ) posted Thu, 25 March 2004 at 8:44 AM
And the full morph rendered. I've done full morphs in Max lots of times with no ill effects :o) So I guess I've done something wrong - perhaps something with the symmetry? I'm bright green with ZBrush :o)
DCArt ( ) posted Thu, 25 March 2004 at 9:08 AM
Attached Link: http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=009969
That is the infamous "face reversal" problem that is inherent in ZBrush. What happens is that the morph flips the points from one side to the other. There are a few ways around it ... (1) ZBrush has a script that fixes the problem. See the attached thread for more info. (2) You can re-import the morphed head back into ZBrush and then resave it again. That will save the morph you already did. Or (3) To get around using the script, and for doing multiple morphs of the same body part (such as the head), import the body part into ZBrush and save out the "reversed" head BEFORE you do any morphs. Then import the reversed head for any morphs that you do later on.
Lord_Lucan ( ) posted Thu, 25 March 2004 at 9:44 AM
or you can use Zbrush v 1.23b which didn't have this problem. Hopefully this will be fixed in V2 - released 31st march - saving my pennies(got 63p so far lol).
TrekkieGrrrl ( ) posted Thu, 25 March 2004 at 9:46 AM
Thanks, Deecey :o) That sounds like an easy fix... If I can find that button to import again L How can ANYBODY find their way around that interface?! O.o
DCArt ( ) posted Thu, 25 March 2004 at 9:47 AM
It sure is different isn't it?! LOLOL
PheonixRising ( ) posted Thu, 25 March 2004 at 10:20 AM
There is a Z script for free downlaod that exports the obj's properly. Just reimport obj and export again and it will flip it back.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
Marque ( ) posted Thu, 25 March 2004 at 11:27 AM
Will current users get the update for free? I've been with ZBrush since the first beta. Marque
Marque ( ) posted Thu, 25 March 2004 at 11:28 AM
Ahh yes, just found out we do. What a great company!!! Marque
DCArt ( ) posted Thu, 25 March 2004 at 11:30 AM
I believe so, Marque ... at least, according to the press release about the impending release, it says that all registered users will get a free update! I think that is VERY generous of them!!! 8-)
