Sun, Oct 6, 5:55 AM CDT
Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Subject: Mapping Complex Figures Very Simply - Looking For Polka Dot Material?
Angelouscuitry ( ) posted Thu, 18 March 2004 at 5:54 PM ยท edited Sat, 24 August 2024 at 1:37 AM
I'd like to apply a Much larger check(And Polka Dot, if I could find one,) pattern(s) to this P5 import, but my guees is that much of this same mapping mayhem will accur. Any suggestions?
agiel ( ) posted Thu, 18 March 2004 at 6:13 PM
Probably.... did you try mapping in both Object and World mode ?
Angelouscuitry ( ) posted Mon, 22 March 2004 at 5:10 PM
Would you care to elaborate on the differance between World and Object modes, maybe post a screenshot or two? I tried looking this up in the help file and failed.
agiel ( ) posted Tue, 23 March 2004 at 8:15 PM
Sorry for the delay... here is a screenshot of the Material editor. In the top right corner, you will find a menu for 'Mapping'. Usually 'World' mapping provides better results if what you want is a unified look to your texture. There are issues with textures with pattern however. It may not be possible to map these patterns without a complex UV mapping software such as Bodypaint or Deep Paint 3D.
agiel ( ) posted Tue, 23 March 2004 at 8:16 PM
Here is the screenshot.
Angelouscuitry ( ) posted Thu, 25 March 2004 at 6:04 PM
Yep it was in World mode. I'm currenlty working on a post in the Carrara forum about .DXF format, and Boolean Union. Anyone know offhand if either of these would help. I really want to see all of the big squares across this figure!
