Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
It's not just P5. Pro Pack did that to me just two days ago. I had to stop the render. Reset the display mode, then resave the document, closed out Poser and then reopen Poser and the newly resaved document. It behaved itself then. Somehow in the crash during render it changed the display settings from Shaded Render to "Actual Render" and just kept trying to render the whole thing. Resetting your display like say, to wireframe and then back to the display setting of your choice should fix it if it's the same problem I incurred. Just be sure to resave the file with the reset Display Settings.
Hi again... I did the Virus check, with no virus found (thank's @ Nortons for updating me day by day :) ) I bought my prog used via e-bay (original CD with package and licence!!!) Just in case: Is there a way, except registering at CL, to find out whether I have an authorisized copy or not?? I'll try the "display setting thing" and let you know about the results.. thank you so fare for your help! J.
If you save the file during an unfinished render you may have that..I had once...That mean you might lose that file.
Hi Folks, after having a "hangup" during rendering a szene.... I closed P, restarted my computer and load the szene again to work on it,.... but during loading the szene, P5 started rendering it, without me having tell it to do so! Ok... shut down P5 again...restart the fu...ng PC again...load the damned szene....and: What the hell.... It is doing it again....and again.... and again... I will not loose this szene! I saved it.. I don't know how often....but it is...gone! Can somebody help?????? PLEASE!!!!! I'm yours if yes!!! I promise!
