Fri, Jan 10, 12:44 AM CST
Subject: Only the head and hair are by Zygote
PhilC ( ) posted Sun, 24 September 2000 at 2:13 AM ยท edited Fri, 10 January 2025 at 12:35 AM
Only the head and hair are by Zygote. If you have been following this it continues from [ here](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=169674) Finally got the CR2 figured out to accept the facial morphs, you have NO idea how picky Poser is in this respect. I was basically right the first time but all it takes is a dot or comma out of place and the figure will not work. Now for the joint parameters .....eeeek! [![philc_agatha_white_on_black.jpg](http://www.philc.net/images/logos/philc_agatha_white_on_black.jpg)](http://www.philc.net)
JeffH ( ) posted Sun, 24 September 2000 at 3:14 AM
Phil, do you use John Stallings' CR2 editor? You won't have a problem with syntax using that.
DTHUREGRIF ( ) posted Sun, 24 September 2000 at 3:14 AM
God, Phil! I am impressed! And I don't envy you one bit! Joint parameters! ::makes the sign of the crossed index fingers to ward off evil:: NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!
thorntoa ( ) posted Sun, 24 September 2000 at 8:17 AM
Wow--looks good! Is she going to be available for sale or freebie soon?????
Allan Thornton
PhilC ( ) posted Sun, 24 September 2000 at 8:24 AM
Yes I use John's utility extensively. However I found at 3 am this morning that when you copy/paste it reverses the line order. ie viewed in the editor:- actor head:1 objFileGeom 1917869114 1634887535 :Runtime:Geometries:....etc storageOffset 0 0 0 is actually:- actor head:1 storageOffset 0 0 0 objFileGeom 1917869114 1634887535 :Runtime:Geometries:....etc when viewed in Notepad. And, no, I have no idea what those big numbers mean :) I somehow managed to get this working last weekend but the figure had an hierarchy error in it. Its taken me all week to duplicate my results. In the end I may just parent the wings to a P4 body and be done with it. I think I just wanted to prove to myself that I could do it. philc_agatha_white_on_black.jpg
PJF ( ) posted Sun, 24 September 2000 at 9:57 AM
Eek, don't fancy yours much. ;-) Anyone modelling their own figures and setting them up for Poser gets a hat off from me!
dwilmes ( ) posted Sun, 24 September 2000 at 10:55 AM
You can use CR2Edit to automatically transfer joint parameters from a similar model and then tweak them. Also use the Morph Channel tools to remove, save, insert morphs automatically. Then create a Phi file (automatically!) to help you see what is going on, along with the List Channels tool. Dan http://www.neca.com/~dwilmes/cr2edit.html
JeffH ( ) posted Sun, 24 September 2000 at 11:15 AM
Phil, Stallings' Cr2Edior is up to version 1.52, which version do you have? Dan, I'll have to try out your program soon. I did try an early version of it, but didn't like the interface. -JH.
PhilC ( ) posted Sun, 24 September 2000 at 12:10 PM
Yep thats the version I'm using Jeff.
brschmidt ( ) posted Sun, 24 September 2000 at 7:13 PM
Nice modeling! Sometimes I spend more time on the cr2 creation than I did modeling the figure... although I haven't tackled a full figure your work is motivating!! Looking forward to seeing this one in the future after you've conquered the twisty's and smoothy's... :~)
JAFO ( ) posted Mon, 25 September 2000 at 1:21 AM
thats some piece of work there phil... ill be watching for updates
Y'all have a great day.
