This will never end. It has to do with human nature. If there is a way to do wrong, someone will do it. Always.
Contact info for the domain holder... Organization: Neirret Web Services Christopher Terrien 18119 FM831 Buffalo, TX 75831 US Phone: 903-322-3209 Email: neirret@qins.net Registrar Name....: Register.com Registrar Whois...: whois.register.com Registrar Homepage: http://www.register.com Domain Name: EQLOV.COM Created on..............: Fri, Apr 07, 2000 Expires on..............: Wed, Apr 07, 2004 Record last updated on..: Fri, Nov 21, 2003 Administrative Contact: Neirret Web Services Christopher Terrien 18119 FM831 Buffalo, TX 75831 US Phone: 903-322-3209 Email: neirret@qins.net Technical Contact: Neirret Web Services Christopher Terrien 18119 FM831 Buffalo, TX 75831 US Phone: 903-322-3209 Email: neirret@qins.net Zone Contact: Neirret Web Services Christopher Terrien 18119 FM831 Buffalo, TX 75831 US Phone: 903-322-3209 Email: neirret@qins.net
register.com is a registrar, meaning they just register domain names. The people you need to contact is the site's host. The contact info points to www.qins.net. However, a traceroute of the domain leads to www.birch.net (auto-redirects to birch.com). Birch.com looks to be a broadband provider. They are in the same area of the US (texas and surrounding areas) as qins.net, so they may be affiliated. I would send an email to both. Here are there contacts for such issues: abuse@birch.net and abuse@qins.net Since it is somewhat unclear who the host may be, make sure to clearly state the issue and the domain/location of the files so they will be able to determine if they are the actual host. It is quite possible the individual is running the website directly from a home PC, connected to a broadband connection from birch.com, using a domain registered by qins.net.
Either contact the guy by phone OR you can go to "REGISTER.COM" and complain as it clearly shows below that the website is showing it as their DNS server. Zone Contact: Neirret Web Services Christopher Terrien 18119 FM831 Buffalo, TX 75831 US Phone: 903-322-3209 Email: neirret@qins.net ================================ Domain servers in listed order: DNS29.REGISTER.COM 216.21.234.85 DNS30.REGISTER.COM 216.21.226.85 ================================
when doing a route trace (see below) the last hop before the actual domain is usually the domain/webhost. In this case it's birch.net Trace eqlov.com (216.212.68.100) ... 1 199.69.204.6 125ms 102ms 110ms TTL: 0 (No rDNS) 2 199.69.204.1 138ms 105ms 105ms TTL: 0 (No rDNS) 3 12.122.252.45 118ms 120ms 115ms TTL: 0 (No rDNS) 4 12.123.193.42 111ms 115ms 111ms TTL: 0 (gbr2-p21.cgcil.ip.att.net [authoritative]) 5 12.122.11.53 120ms 125ms 105ms TTL: 0 (tbr2-p013602.cgcil.ip.att.net [authoritative]) 6 12.122.10.46 125ms 129ms 113ms TTL: 0 (tbr2-cl7.sl9mo.ip.att.net [authoritative]) 7 12.122.10.90 140ms 140ms 140ms TTL: 0 (tbr2-cl6.dlstx.ip.att.net [authoritative]) 8 12.123.16.245 135ms 140ms 135ms TTL: 0 (ggr1-p370.dlstx.ip.att.net [authoritative]) 9 64.200.232.201 138ms 135ms 160ms TTL: 0 (IPP-dllstx9lce1-pos5-0.wcg.net [authoritative]) 10 64.200.232.13 139ms 130ms 140ms TTL: 0 (dllstx9lce1-pos2-0.wcg.net [authoritative]) 11 64.200.232.209 140ms 125ms 135ms TTL: 0 (dllstx1wcx3-pos12-0.wcg.net [authoritative]) 12 64.200.240.82 150ms 140ms 145ms TTL: 0 (tulsok6wcx3-oc48.wcg.net bogus [authoritative]) 13 64.200.183.34 135ms 135ms 140ms TTL: 0 (tulsok6wcx2-oc48.wcg.net [authoritative]) 14 64.200.240.49 135ms 130ms 130ms TTL: 0 (chcgil1wcx2-oc48.wcg.net [authoritative]) 15 64.200.103.58 135ms 125ms 140ms TTL: 0 (chcgil1wcx1-oc48.wcg.net [authoritative]) 16 64.200.247.14 150ms 145ms 146ms TTL: 0 (chcgil1wcx1-birch-pos.wcg.net [authoritative]) 17 216.212.127.34 147ms 145ms 145ms TTL: 0 (host127-34.birch.net ok) 18 65.16.60.169 153ms 159ms 150ms TTL: 0 (host60-169.discord.birch.net ok) 19 216.212.68.100 155ms 145ms 150ms TTL: 51 (eqlov.com ok)
Attached Link: http://samspade.org
There are utilities that will do it for you. NeoTrace is very good but Sam Spade (see link) is my favorite (besides it's free :-). You can also do it from a dos prompt on your machine by entering the command tracert followed by the domain name you're trying to track down.This thread should be moved to the Product Showcase forum! uh.....shouldn't it? ((someone talked about a "Powered by Gallery" software link.......))
Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=25944
Register.com certainly IS the host, so lodge your complaints there. One of the artists called and asked, and Register.com confirmed that they are hosting the site. Relevant thread: http://www.poserpros.com/forums/viewtopic.php?t=25944 It's true that name servers don't always directly translate, but most of the time they do, and it's a pretty good place to start looking. ;-) bonni"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
Well, due to the fact that you are now discussing "What should I do if......?", in a general sense -- in the light of that, this thread needs to be moved to the Community Center forum.......
Just don't mention Vue, or things will get really confused....... Oops.....I went and done it, myself.
Attached Link: http://www.eqlov.com/gallery/view_album.php?set_albumName=Sigs
Please forgive me if this is considered off topic, but is any of this stolen work yours? The person who brought it to my attention on another board and I have tracked down a few of the artists, but some remain to be identified. Wonder if I should tag this "violence" - lol. Makes me wanna bust some heads.
