Wed, Jan 8, 8:57 AM CST
Subject: Thumbnails P5 Sr4 Tip
ojim ( ) posted Tue, 30 March 2004 at 3:23 PM · edited Wed, 08 January 2025 at 8:33 AM
Thought I would post a tip before asking a question. If you are having trouble seeing thumbnails in P5 it may be because there are more than 100 thumbnails in that folder. What you will see is a list of the files. This is actually a feature of Sr4 but you may have forgot about it, as I did. You can easily change the default number see below. This happened to me when I purchased a package of 50 poses each for V3, M3, and SP3. It may also happen if you have combined some pose files. Hope this will save someone some angst. Here is the note I got from the Curios Labs. Support Team
Hello James,
It's a feature!
From the SR-4 readme:
Library
  • If desired, Poser can now omit the thumbnails when browsing library categories that contain more than a certain threshold of items. Default is 100 items per subfolder. Please adjust the previewNum value in Runtime/prefs/LibraryPrefs.xml if you prefer a different value.
Kind regards,
Dave-So ( ) posted Tue, 30 March 2004 at 8:05 PM
ah...so that's why I have lists now...I was really pod at that.... Thanks very much :)
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
Dave-So ( ) posted Tue, 30 March 2004 at 8:09 PM
bummer..it appears you can't go larger than 100...I still have lists in a couple of folders... I want thumbnails so I can see what the stuff is... guess its time to split runtimes or something
Tyger_purr ( ) posted Tue, 30 March 2004 at 9:34 PM
Dave-so: you should be able to make it over 100...i dont know if this is what is happening or not but make sure your not in poser when you make the change. some of the xml files get rewritten by poser while your in poser.
My Homepage - Free stuff and Galleries
Tyger_purr ( ) posted Tue, 30 March 2004 at 9:47 PM
something i found particularly helpful is making larger thumbnails. apparently in p5 you can make them as high as you like. i went in and set my document window size to 91 by whatever and put the characters in, posed them, rendered them and saved as png. I redid the pngs for many of my people/characters and mats so that i could see what i was looking at. I have some as large as 91x250
Dave-So ( ) posted Tue, 30 March 2004 at 9:51 PM
nope..it isn't working..still have a list..maybe there's something else happening..
TrekkieGrrrl ( ) posted Wed, 31 March 2004 at 12:52 AM
Tyger-Purr, that works in Pro Pack too :o) Yeah it's a great way of getting legible thumbnails, some of my prop packs has thumbnails sized 91x182 (to keep the ratio) But have you noticed the drop shadow can't quite cope with it? G
Bobbie_Boucher ( ) posted Wed, 31 March 2004 at 9:26 AM
This is an easy fix. You can use Windows Notepad, or a good text editor. 1.) Make sure you're not running Poser 5 1.) Navigate to your Poser 5 folder, then Preferences 2.) Make a copy of LibraryPrefs.xml 3.) Change previewNum= to a higher number 4.) Save the file.
Dave-So ( ) posted Wed, 31 March 2004 at 6:08 PM
yeah..I went from 100 to 200 but it still did not work :) now I went to 500.... and, viola...it works... so, if you have a lot of stuff , you may need a much higher number in there to get your thumbs back. I thought it was just 100 per folder, but it must be the total number of thumbnails within the runtime.
layingback ( ) posted Wed, 31 March 2004 at 6:28 PM
Dave-So, I had same problem. My hunch is that it's just doing a total file count for the folder to do the check, so the limit number you need is x2 (.cr2/.pp2/.etc + .png) or x3 if you have .rsr's about too. But I could see no reason for a low number (nor could I see any reason for any limit in the first place ;-) so I just added a 0 on the end: 100 => 1000 :-O
ojim ( ) posted Wed, 31 March 2004 at 7:19 PM
Glad to hear that you got it to work. Glad too that I brought up the issue as it seems there are at least a few more happy campers out there and I got a great tip about the size of the images.
Sir_Mikal ( ) posted Mon, 05 April 2004 at 9:22 AM
Thanks for the tip.. I can SEE again.. At least I can see my thumbnails again.. :-)
ojim ( ) posted Mon, 05 April 2004 at 2:46 PM
You are more than welcome. Isn't it a real relief to see the thumbnails again. I think the SR4 should have come with more of an explanation or warning. I as usual skim read it and most either didnt apply to me or went over my head. Perhaps they should have entered that text in BOLD. Oh well at least we can see again. Happy Rendering. Jim
Kalypso ( ) posted Thu, 29 July 2004 at 9:31 AM
Site Admin Online Now!
As a real latecomer to Poser 5, thanks Jim for posting this tip! You just saved me some hair :)
