Mon, Feb 24, 11:21 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Subject: Is it hard to make props for poser4?
twisted_angel_9 ( ) posted Tue, 06 April 2004 at 12:35 AM · edited Mon, 24 February 2025 at 11:15 PM
I want to make a broom, but know NOTHING about making things for poser... Is there anywhere that tells? also is there a place that can tell me how to make my own pose sets? Thank you.
geoegress ( ) posted Tue, 06 April 2004 at 1:52 AM
Poser itself is not a modeling program- but a broom is relitivly simple- a little creative use of primatives might do it :) when you've made the broom to your likes- export as wavefront obj the reimport it- it will be all welded together as one item :) As far as poses go- yup- pose your character then in the Pose libary click the (+) sign and it will be saved to the libary.
numanoid ( ) posted Tue, 06 April 2004 at 2:07 AM
Do a search in this forum for Dr Geep. Follow all the good doctor's lessons, and you will be making brooms and poses like a master in no time. PS There are about 40 lessons covering almost everything you will ever need to know about Poser.
numanoid ( ) posted Tue, 06 April 2004 at 2:10 AM
If you click on the Poser banner at the top of this page, the one that says "Poser Forum", it will take you to the backroom. There you will find a button that says tutorials. Happy studying!!
xantor ( ) posted Tue, 06 April 2004 at 8:40 AM
Attached Link: http://www.wings3d.com/
Wings3d is a free object making program that can be used for making props and is available at the link.
pakled ( ) posted Tue, 06 April 2004 at 9:12 AM
dang xantor, that's my line!..;) Poser can import .3ds, and .obj formats, just gotta get a handle on the scaling and weld identical vertices..I've done a couple, no great shakes, but a good learning experience..;)
TrekkieGrrrl ( ) posted Tue, 06 April 2004 at 12:39 PM
Something like a broom is easy to make with Poser's primitives if you're not TOO picky... Here's an example. 2 cones, a torus, a cylinger ande a somewhat elongated ball, textured in Poser 5's material Room.
ockham ( ) posted Tue, 06 April 2004 at 3:28 PM
You can make the basic props more flexible by un-hiding their Taper controls. This is most useful with the Y-taper on the Box, Cylinder, and Ball. Make a backup copy of the PP2 files, then locate the 'hidden 1' line under each of the taper parameters, and change 'hidden 1' to 'hidden 0'. --------- Original: taperY taper Y { name taper Y initValue 0 hidden 1 --------- Becomes: taperY taper Y { name taper Y initValue 0 hidden 0 --------- With the added Taper Y control on the Cylinder, you can make a broom like this.
My python page
My ShareCG freebies
shadownet ( ) posted Tue, 06 April 2004 at 7:01 PM
Here is a 9mm I made entirely in Poser using the primatives, grouping tool, and magnets. Also used some of the primatives from maclean's prop-o-rama set 1,2,3, in free stuff at 3Dcommune - mostly for internal parts not seen. I have it to where it can be field stripped. But then I tend to go overboard with things. LOL
twisted_angel_9 ( ) posted Tue, 06 April 2004 at 8:03 PM
Wow, thanks for the help.
