Thu, Dec 12, 8:19 AM CST
Subject: 2d surface texture and transparency question!?
ZoSoSwiM ( ) posted Tue, 06 April 2004 at 6:35 PM · edited Thu, 12 December 2024 at 8:16 AM
I want to take a 2D square and use a JPEG image for the texture. I also want to use a transparency on the same image so that the square doesn't have edges. EX: figure of a person, with a trans map or something around it so only the person shows up. So I basically want the person to be clear without having the boarder of the square it's on... now how do i do it, i hope i've explained it okay?!
danamo ( ) posted Tue, 06 April 2004 at 7:12 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=584184
This question comes up a lot, particularly with users who are fairly new to the program. This link to an older forum post should clarify things. If not, let us know.
dan whiteside ( ) posted Tue, 06 April 2004 at 8:44 PM
Here's a quick set-up that usually works: You'll need two images, the color image you want to use and an alpha image with all that you want to be transparent colored black and all that you want to see colored white. In Bryce click the gold "Leo" man in the Create palette, this will open the Pic Editor. Click on an empty brown slot and select the color image from the file selector. The image loads into the left preview box. Now click the load button above the middle preview box and load the alpha image. Click OK and Render - that should do it for most basic stuff. HTH; Dan
ZoSoSwiM ( ) posted Tue, 06 April 2004 at 10:04 PM
awesome. thanks alot. i'll give it a try. i'm trying a project for my college digital class:)
ZoSoSwiM ( ) posted Tue, 06 April 2004 at 10:31 PM
well i tried it and i'm still having a problem. i did as shown and i still have the box around the figure, here's a picture.
Slakker ( ) posted Tue, 06 April 2004 at 11:10 PM
you didn't marble your transparency channel.
ZoSoSwiM ( ) posted Tue, 06 April 2004 at 11:17 PM
Marble the trans channel? what do you mean?
danamo ( ) posted Tue, 06 April 2004 at 11:18 PM
Remember: when you go to make your pict object click on the "Leo" icon, not the 2d square icon. If you click on Leo your transparency and other settings will be done for you, assuming your mask is set correctly.
danamo ( ) posted Tue, 06 April 2004 at 11:21 PM
This is how I masked a fern...
danamo ( ) posted Tue, 06 April 2004 at 11:24 PM
The diffuse, ambient, and transparency channels are already set for you if you click "Leo" first...
danamo ( ) posted Tue, 06 April 2004 at 11:26 PM
And finally...
ZoSoSwiM ( ) posted Wed, 07 April 2004 at 7:04 AM
Alright, now thats real nice. Thanks everyone!
