Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Attached Link: http://www.padd.com/market/product/product.php?prod=3dtk
I've had that problem (duplicating motion paths) lot of times... That's why I stopped using Carrara's animation features but for the most simple things... I'm afraid that Carrara's animation tools (specially motion paths) s..k (sorry...) I think they are aware of it and the next version of Carrara will have better animation tools (or at least that's what they've told) I still love Carrara and use it for stills but for animations I would recomennd you to buy the $99.00 3DToolkit 2.5. It's a very good productions quality program. Its a very fast Phong renderer I belive, No real reflections (which you can fake with maps) , transparency yes. It's the little brother of Universe ( Kind of like Carrara and Carrara Basics) You can export models from Carrara and import them there. Or vise versa (hope I spelled that right.. ) It has a NURBS modeler that is somewhat different that Carrara's but It complements it quite nicely. I specially like the boolean operation and beveling options.... I go back and forth between the two and like that workflow a lot. In the animation departement you have Bezier motion paths that work Beautifuly (like you would expect Carrara's to do) F. Curves editor, deformers, etc etc Also check the other DV garage's products. They usually work with the Toolkit but almost all of them can be used with other 3d products. Really can't go wrong with that 99 investment if you are serious about animation.. :) Hope I could help you a little with a different opinion Good luck with that fjvThis problem applies to all objects with motion paths. It happens when selecting selecting a different object in the scene and then selecting the object with the motion path right afterwards will somehow generate a duplicate palette and motion path that "lingers." A work around that sometimes works would be to deselect all objects or select just the Scene from the instances palette and move to another room (i.e. modeler, renderer, storyboard) and then select the object with the motion path. Do not select another object in between. If this doesn't work you could also save the project and reopen it and then select the object with the motion path. This usually will get rid of the extra motion path and palette but you must avoid the sequence of selecting one object and then the object with the motion path otherwise the duplicate will pop up again.
OK, I created a motion path per the manual. Fine. I adjust some other things, then come back with the selection tool and click on a motion path point to adjust it and suddenly I have two motion paths! But this doesn't happen all the time. What don't I understand about adjusting motion paths, please? - Bill
