When I hear "brooding" it makes me think of gray skies and clouds, maybe in the evening. Anyway, so far it is looking real good. The 2 rocks farthest out look placed too perfectly. The 3 rocks could be scattered a bit more. Everything is leading the eye to the right until you get to the darker water which is almost parallel with the bottom edge. Makes it a bit distracting. I keep looking at that rock on the right. It isn't really shaped like a rock. I'm also working on my composition which I have a hard time with, so I'm practicing while looking at your image. :) You have a really good start here. Can't wait to see what the point of interest is. :)
~Damia~ LeviathanPhotography
Attached Link: http://www.j.b.allen.btinternet.co.uk/galcode/Lowtidetut1.html
Is this the tutorial you were thinking about? (Jonathan Allen)There are a lot of things worse than dying, being afraid all the time would be one.
"I must go down to the seas again, the lonely sea and the sky" (Original by John Masefield, but I'm persuing a slightly different tack - still a quote, but by a different author) C&C welcome (in fact needed) I'm looking for that wide, lonely, brooding look... I have a vague recollection of a tutorial about "low tide". Tried to implement it from memory. (My memory makes a sieve look watertight). There are a lot of things I know I have to improve, (too many abrupt transitions: "dry" sand too distinct from the "wet" sand; the "seaweed" in the water is not very believable; the foreground needs more detail), but just at the moment I'm trying to concentrate on composition, my weakest point of many. So, as I said, C&C welcome:-)) Cheers, Diolma
