Sun, Feb 2, 9:59 PM CST
Subject: Bryce underwater scenes
jsj ( ) posted Mon, 25 September 2000 at 10:23 PM ยท edited Thu, 30 January 2025 at 9:09 PM
Please need help with a translation from german to english. The two pages I can't quite understand are at Mitch's 3D Seite. Here are the links for the pages http://www.mitch3dseite.de/uw_tut03.htm and http://www.mitch3dseite.de/uw_tut04.htm If someone can help with that I be greatful.
cult_7 ( ) posted Tue, 26 September 2000 at 3:19 AM
I had the same problem because I dont know any german.But fortunately it has pictures.All you have to do is set bryce as the pictures.Its very easy
jsj ( ) posted Tue, 26 September 2000 at 9:25 AM
I got as far as page two. The part about the caustic texture and the light on page 3 I did not quite get it. Cult 7 is that any way you can explain it to me cause Im not sure what kind of light to use (infinit, directional, where tp place it)and the caustic texture, is it applied to a 2D face vertical?
cult_7 ( ) posted Tue, 26 September 2000 at 12:56 PM
Hi.Well I think he means to make a parallel light as big as the scene you are making(actually as big as the caption of the camera viewed from top I think).Then you have to apply the caustic texture as gel(It can be downloaed from his site).Then edit your light.Apply 200 for lightness I think and 0 for softness as the scene will seem unrealistic with more softness.(I am not sure about this).Mark volume visible light and infinite light and linear fallof.Next is the editor for texture used as gel.Hope that I got it right ;)
cult_7 ( ) posted Tue, 26 September 2000 at 12:57 PM
jsj ( ) posted Tue, 26 September 2000 at 6:15 PM
Thanks for your help cult_7. I'll give it a try a.s.a I can, regards.
ub52 ( ) posted Wed, 27 September 2000 at 12:43 PM
OK. Here is what I did and it worked pretty well. Go to the following site: http://babelfish.altavista.com/translate.dyn Click the Website radio button and enter the URL for the above site. In the pull down list box just below, select German to English and click the translate button. Wahlah, it returns the page in its original format but translated into english.
Apache2k ( ) posted Wed, 27 September 2000 at 6:24 PM
Attached Link: http://members.nbci.com/eetu
Hello folks, i did put a tutorial into my page if you are interestet. Check it out. The page loads sometimes slowly. Its in the tutorials section. Plese give me some feedbacks so that i can improve my next tutorials. Thanks
jsj ( ) posted Thu, 28 September 2000 at 1:47 AM
Thanks to cult_7, UB52 and Apache2K for all the help on this matter. BTW Apache I didi not find a tutorial section on your site?! Perhaps you will be kind enough to send me the link. Thanks again
Apache2k ( ) posted Thu, 28 September 2000 at 3:47 AM
well it is on the top menu where all the galleries , isfo, download, tutorial....JSJ. Anyway here is the direct link to there. http://members.nbci.com/eetu/tutoriual.htm
