The textures are fantastic, what I see that bothers me is the transition between the wall and the floor seems to sharp. Love those stones wish I could get some for my yard. I'm not too familiar with caves so I don't know what real ones look like at the wall bases. I agree with eelie, I think this is looking great.
I think it looks great. I do agree that the transition from wall to floor is a bit sharp. The textures are great though. It's coming along really well! Keep it up. And welcome home to Nor CA ;)
~Damia~ LeviathanPhotography
Two things I can think of... One thing is that the grit seems a bit "too clean". I would expect to see some difference in size:
Another thought of why it might not look good to you is that the color seems not the same as the color of the walls (but that might also be the lighting playing tricks on me). The eye expects the same color of the sand as it is made from the same material as the rocks.
Besides all... I love it as it is already
I agree with Kylara on this, the first thing that struck me was that the detritus is too much of a muchness, needs some variances. Love the floor, how did you dod that texture?
The greatest part of wisdom is learning to developĀ the ineffable genius of extracting the "neither here nor there" out of any situation...."
@zescanner - I improvise as i compose, so i usually don't know what i'll end up with when i start. I wanted to do something with a tunnel, so i started building a small "stage" set of a section of tunnel with a number of different types of possible camera angles. So far, i've used the cameras to work on and monitor the textures. As i progress, i get more of an idea of where the piece is going. My next big step is to redo the walls and ceiling as crumbling carved shapes and spaces. As i go on, i'll get a sense of whether or not the "object" will be visible or not, or even if i go in a different direction altogether. IOW, to make a long story short: i don't know. 8o)
Thanks bigbadelf, I had a feeling you did it something like that. Was wondering if I could use the tecnique to improve the paving stones on my parade wip. Sorry about the typo, fingers out of sync with brain, as usual. Hope your move goes OK.
@chohole - If you didn't know, the ABC combination technique is in the manual. The move went smoothly, thanks. @zescanner - While on the road i realized what the archeologists found - a coke bottle! LOL. I don't know if i'll use the bottle or if that's even gonna be the backstory for the final image. We'll see how it evolves. I thought it was a great punchline, though! 8o) @Kylara - I agree about the need for rocks. Once i pick a final camera angle i'll populate it accordingly. As for the sand color, i agree that one would expect it to be the same as the mass of rock it came from. Unfortunately, that's rarely, if ever, the case. Ground rock is usually lighter in color than a chunk of the rock (try scratching one rock on another). These colors are still in motion, anyway. The green on the rock doesn't work in the scene.
