Fri, Nov 15, 3:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: non-symmetrical eyes for v3?
Drezz ( ) posted Thu, 15 April 2004 at 1:17 AM ยท edited Thu, 14 November 2024 at 8:04 PM
hey does anybody know where i can find a morph for victoria 3 that will move only one eye up or dwn, right or left, instead of both? im tryin to create a friend and one of her eyes is a little higher than the other, so im kind of at a loss unless somebody can help...
Little_Dragon ( ) posted Thu, 15 April 2004 at 3:30 AM
Do you have Poser 5? If so, you can use the Split Morph function to divide a morph into separate left and right sides.
Dave8 ( ) posted Thu, 15 April 2004 at 4:14 AM
or u could just click on the eye u want to move and use the dials
hauksdottir ( ) posted Thu, 15 April 2004 at 4:52 AM
...but it isn't just moving an eyeball. You have to move the lids as well. Morphs usually have associated PBMs so that things will move together. Carolly
Momcat ( ) posted Thu, 15 April 2004 at 6:29 AM
Split morph? How do you do that? I've never seen that function.
ockham ( ) posted Thu, 15 April 2004 at 9:57 AM
Applying a Wave to the head will do the job quite easily. As soon as the Wave appears, you'll see one eye socket is higher than the other; you can then adjust the amplitude, phase and offset until it's right.
My python page
My ShareCG freebies
Little_Dragon ( ) posted Thu, 15 April 2004 at 5:42 PM
>> *Split morph? How do you do that? I've never seen that function.*
Click on the little arrow to the right of a morph, and you'll see a list of options (reset, delete, split, etc.).
Momcat ( ) posted Thu, 15 April 2004 at 6:21 PM
Well now! Thank you so much for pointing that out. That's going to
make a lot of things much much easier. >^_^
hauksdottir ( ) posted Thu, 15 April 2004 at 8:38 PM
The new morphs will appear down at the bottom of the dials. I need to see if that works for things like making a chin a bit longer on one side. A quirked eyebrow or lop-sided dimple help to add character to a face. Carolly
Drezz ( ) posted Fri, 16 April 2004 at 2:00 AM
That is the sweetest thing ive learned so far. Thanks a million. That will help a ton on some of my stuff.
