Sat, Jan 25, 2:56 PM CST
Subject: Strange artifacts when rendering window blinds---can anyone help?
poser ( ) posted Sat, 17 April 2004 at 7:22 PM ยท edited Fri, 10 January 2025 at 10:51 PM
Hi everyone,
I'm having a problem rendering what seems to be a simple prop--the window blinds from the great Hospital Interiors set by Moebius87.
I'm using the firefly engine in P5 and have tried playing with settings such as texture filtering, removing backfacing polygons, shading rate, etc. but so far no luck.
This is a simple prop without any textures.
Any help would be greatly appreciated.
Thanks in advance!
ockham ( ) posted Sat, 17 April 2004 at 10:15 PM
Have you tried changing bucket size? The moire effect looks like an aliasing conflict between the "bucket" edges and the blind interval. Try making bucket size MUCH larger than the spacing, and see what happens.
My python page
My ShareCG freebies
Moebius87 ( ) posted Sun, 18 April 2004 at 3:06 AM
Looks to me that you might have loaded up the window blinds several times. I'm not very Poser savvy at all, but it could be that the render engine is getting confused with co-located polygons. :o) Just an observation. Cheers! M P.S. Yes... I suck big time at texturing stuff for Poser. :o(
Mind Over Matter
"If you don't mind, then it don't matter."
MungoPark ( ) posted Sun, 18 April 2004 at 6:21 AM
These are probably one sided polygons, you might check stewers side for a work around (http://www.keindesign.de/stefan/poser/firefaq.html#8) - The moire effect comes with blinds sometimes in in PP4
poser ( ) posted Sun, 18 April 2004 at 6:44 AM
Thanks for the input, everyone.
Moe---The prop is definitely loaded only once.
ockham---I tried bucket sizes from 32 to 512 but it made no difference.
MungoPark---I'll check that link out. The blinds do seem to be one-sided as the beige material color disappears when you look at the reverse side (it's black).
Thank you again.
maclean ( ) posted Sun, 18 April 2004 at 10:39 AM
I tried my own blinds in P5 but they seem to be OK. Here's a pic. I used the default Firefly settings, then I messed around changing everything I could, but they're fine on all settings. I'm guessing it's something in the model itself. In P4, I always get the moire effect with blinds in the preview window. There's nothing you can do about it. But renders are always OK. mac
