Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
There are individual check boxes for Bulges in the Joint editor.
It sure looks like a JP issue more than anything else. You COULD try usinh spherical falloff zones - or turn them off if they're there and see if it helps. Can you post a pic of the bend JP's for the thighs? I have an idea of what's wrong...
Great :o) JP's are a relatively new subject to me, so I wasn't 100% sure it would work :o) but since I found out what the lines mean I had this lightbulb-thing go off over my head G Whatever is between the red and the green angles is what is "squished"/"stretched" - verything within the same colour stays put, more or less.
Do all figures have deformations like the bulges in them? I am making a figure and the hip deforms badly when the figure bends, I have tried fixing it with the joint editor and that doesn`t work, so I thought if there are deformations in the hip for bending etc in the cr2 then there must be some way to switch them off and fix my problem.
