Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 6:51 am)
That is what I get without the update on Vicki ... With the update I only have to soften about 1 (maybe even less) and do the no nipple morph ... That is with either the vickie map 1 or the no map .. didn't try the other one ... It was simply a question of updates ...Got so dang confusing for a while
Normally I'd do that, but if you're going to apply a transmap to the catsuit, then you want some body part to be visible through the holes. I made a transmap with a large hole cut out over the stomach area. So you want that part to show through but you don't want the body ripping through in that area. Liz Pope Dreamspinner Inc.
Oh, that was misleading of me. I didn't mean she has to use the second map because I use both (actually I don't use either now--I'm using other maps--both some I've adapted from P4 and Cindy's), just that mine is called Vickimap2 I believe. I think I deleted the nomap 2 and left the map one on, but actually use my 'white' vs. 2. Hope this clears THIS up LOL. Yes, I remember that was very confusing. Melanie had all the versions on and couldn't figure out which to use, as I remember.
Hello, This is Eric at Zygote. We are unable to duplicate this problem. We do feel that this problem is due to the version of Victoria you are using. You will recall that we released a .cr2 update of Victoria after her initial release where the actual .cr2 is named 'Vicki.cr2'. The center points in her shoulders are slightly diferent in this version. I suspect this to be the cause of your problem. Make sure your model is called Vicky instead of Victoria. Feel free to email us at tech@zygote.com if you have any other questions. Eric Allen Zygote Media Group
![file_134557.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_134557.jpg)
I used the Soften Hip dial at 1.600. Solved the break thru at the hip and stomach area but the shoulders still stick out. This figure is one called VikkiMap or something similar. Liz Pope
