Wed, Feb 26, 2:25 AM CST
Forum Moderators: RedPhantom
Subject: So... what is going on?
jsj ( ) posted Mon, 02 October 2000 at 9:16 PM ยท edited Wed, 26 February 2025 at 2:02 AM
I'm sure most of you are familiar with the characters created by Yamato and Kozaburo, LinLin, Mimi, etc. Well something strange began hapening. My Poser4 opens all characters but refuses to open Nene401SE and YoungNene. The program locks up and shuts off. All other files open fine. First I thought maybe the copies I have are corrupt so I downloaded new files. No luck. I uninstalled and reinstalled Poser4. Use the upgrade to 4.0.1 than 4.0.2 than 4.0.3. No cigar. Reformated the computer. Nada. Installed on Win98. No. Win98SE. Nono. WinME. Zilch. Win2000. Niet. Win2K Advanced Server... I can go on... Can someone tell me what's going on?
Serpent ( ) posted Mon, 02 October 2000 at 10:27 PM
Hello, This is just a wild guess.... I had a similar experience once with a SCSI harddrive. I had to format the drive with format /U . Poser would just open and say "Out of memory". Reinstall of Poser had no effect. After complete format of the HD and reinstall it worked fine. If you already formated the drive then I'm not sure. Could be a bad call to a texture path that isn't correct. Try deleteing the troubled characters rsr files from RuntimeGeometriesect. and then let Poser rebuild them. Thats all I can think of. Serpent
jsj ( ) posted Mon, 02 October 2000 at 11:08 PM
I'm not using scsi and I'm familiar with the switch /U (for unconditional) wich I always use when formating, however I haven't been able to open the original pz3 files. I was hoping that some kind soul would send me the CR2 and SRS files for Nene401SE and YoungNene. They can be uploaded to my I-Drive http://www.idrive.com/. Login - mypz3 Pass - models - TIA.
Scarab ( ) posted Mon, 02 October 2000 at 11:44 PM
Have you loaded any other hi-res or large models/characters recently....I have found that certain models, if in the library, cause poser to act in this way...removing the model seems to clear things up. Scarab
jsj ( ) posted Tue, 03 October 2000 at 12:52 AM
I have downloaded to these files from Poser Factory twice. 2times with cable and 2times with 56K wich I have both for my business. The other hi-res models I have on Runtime are Vicky and MillMen wich I removed in one occasion.
Scarab ( ) posted Tue, 03 October 2000 at 9:23 AM
I had not noticed the problem with the zygote figures, but I had similar difficulties once after adding the "Sarenna Lee" figure to my library. Scarab
jsj ( ) posted Tue, 03 October 2000 at 3:57 PM
Thanks to all of you who tried to help on this matter. I believe I solved the problem even thought I don't know the cause.
