Tue, Nov 26, 11:08 PM CST
Subject: Poser 5 thumbnails?
Zarabanda ( ) posted Fri, 23 April 2004 at 2:04 AM · edited Sat, 10 August 2024 at 1:52 AM
I've created both .rsr and .png thumbnails for a mat pose and both work in poser 4. The pose was created with mat pose edit and works fine. But whatever I do the thumbnail doesn't show up in poser 4, its just blank with a transparent circle. so if the thumbnail works in poser 4, can anyone tell me why its not working i poser 5? the .png was created in photoshop 7 and the .rsr was created in p3do explorer.
jasmina ( ) posted Fri, 23 April 2004 at 5:04 AM
I remember that thumbnail format of png must be a indexed color with 256 color. Convert it with Photoshop before saving.
TrekkieGrrrl ( ) posted Fri, 23 April 2004 at 5:27 AM
It's probably the bug in P3d0Explorer, in the latest version the rsr2png is wrong, it reverses the alphachannel. Download the PLUGIN called rsr2png and put that in P3DO instead, and I think it will make them work :o)
Jackson ( ) posted Fri, 23 April 2004 at 10:58 AM
In Photoshop, make sure the image you want isn't the background. If it is, select it and make it a layer then delete the background layer. You should only have one layer now: Layer 1. Also check the Channels palette and make sure there's an alpha channel. Save it that way and it should appear in Poser.
Zarabanda ( ) posted Fri, 23 April 2004 at 1:34 PM
jackson, your action saved me! you da man, Thanks to everyone!
Jackson ( ) posted Fri, 23 April 2004 at 1:43 PM
You're welcome; glad to hear it worked ;)
