Sat, Jan 25, 1:17 PM CST
Subject: Gone and done it...
SoonerTW ( ) posted Tue, 27 April 2004 at 9:54 PM ยท edited Sat, 11 January 2025 at 1:55 PM
Well I officially got tired of the mess that was my runtime folder as well as the drive it was on and wiped out 100 gigs worth of hard drive space. I mean Fdisk, new partitions, the works. I had forgotten what it was like to have totally empty drives. Now that I got poser 4 & 5 installed again I need some help here. I did backup my runtime folder but am looking for the easiest way to pull the poser stuff in while rearranging it. I am not looking forward to renaming 3 gigs worth of folders by hand and copying it back over but at the moment I see no other route. Anyone got a trick to use for this, otherwise I am going to be at this all dadgum week.
TygerCub ( ) posted Wed, 28 April 2004 at 4:05 AM
No other way to put it: Yer Skrood! Good luck.
PabloS ( ) posted Wed, 28 April 2004 at 5:21 AM
Correct Reference Pro might help. It won't do the rearranging (I don't think) but will fix any reference files you screw up in the process.
EnglishBob ( ) posted Wed, 28 April 2004 at 5:22 AM
P3dO Explorer is good for seeing what you've got in your folders. Here's a radical idea - don't copy everything back. I did a rearrangement like this a while back, and apart from the basic stuff I only copied things back into the libraries when I realised I needed them. Needless to say, there's a lot of things that I never used more than once which are still in my backup.
Aeneas ( ) posted Wed, 28 April 2004 at 6:58 AM
While installing, I made several backups of my runtime folder: -a first one with the P5 stuff (that I didn't install as I have no use for it), then, after this copying and setting P5 to open a blank studio, I deleted all items except for ground.tif and camera.obj (P5 wants them at startup). -a second one with all the DAZ stuff I have. I think Daz does an incredible job, but their.exe files for installing are so slow...and offer no option to browse to where you want everything installed. -a third one with DAZ plus the things I bought at Renderosity (and a few on other sites, I confess) -a final fourth with the freestuff. Everything is neatly organized, and there were no problems with wrong files or references. Advantage: I have the original Runtime, and can, if I want to, go back to only DAZ, or everything except for freestuff etc etc. Indeed, more work at the start, but no nuisance later on. My two Eurocents.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
SoonerTW ( ) posted Wed, 28 April 2004 at 7:18 AM
Well I got most of my Daz stuff reinstalled to P5, that generally arranges itself pretty well. Tonight I plan to unzip all of the zip filesI have ammassed over the years to one drive and sort through them. It's going to take a while but it should be doable.
nruddock ( ) posted Wed, 28 April 2004 at 2:06 PM
@Aeneas
The DAZ installers do allow you browse to a folder, you just need to click on Cancel or hit escape while it's searching.
The very newest ones only search if you ask them to.
Aeneas ( ) posted Wed, 28 April 2004 at 5:10 PM
Glad you mention this, but why is this so hidden? Having to check that oine wants to cancel installation to get to the option for browsing seems to me a bit bizarre.
nruddock ( ) posted Wed, 28 April 2004 at 5:30 PM
Took me a while find this out, but as mentioned they've made searching optional which is much better.
I think most people (once they aquire large amounts of stuff) get into the habit of unpacking things into a temporary folder to check, fix, and organise.
