Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
P3dO Explorer is good for seeing what you've got in your folders. Here's a radical idea - don't copy everything back. I did a rearrangement like this a while back, and apart from the basic stuff I only copied things back into the libraries when I realised I needed them. Needless to say, there's a lot of things that I never used more than once which are still in my backup.
While installing, I made several backups of my runtime folder: -a first one with the P5 stuff (that I didn't install as I have no use for it), then, after this copying and setting P5 to open a blank studio, I deleted all items except for ground.tif and camera.obj (P5 wants them at startup). -a second one with all the DAZ stuff I have. I think Daz does an incredible job, but their.exe files for installing are so slow...and offer no option to browse to where you want everything installed. -a third one with DAZ plus the things I bought at Renderosity (and a few on other sites, I confess) -a final fourth with the freestuff. Everything is neatly organized, and there were no problems with wrong files or references. Advantage: I have the original Runtime, and can, if I want to, go back to only DAZ, or everything except for freestuff etc etc. Indeed, more work at the start, but no nuisance later on. My two Eurocents.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Well I officially got tired of the mess that was my runtime folder as well as the drive it was on and wiped out 100 gigs worth of hard drive space. I mean Fdisk, new partitions, the works. I had forgotten what it was like to have totally empty drives. Now that I got poser 4 & 5 installed again I need some help here. I did backup my runtime folder but am looking for the easiest way to pull the poser stuff in while rearranging it. I am not looking forward to renaming 3 gigs worth of folders by hand and copying it back over but at the moment I see no other route. Anyone got a trick to use for this, otherwise I am going to be at this all dadgum week.
