Thu, Jan 9, 3:55 AM CST
Subject: What to do when someone else is pretending that he made an object, while it is
SubTen ( ) posted Sat, 30 September 2000 at 8:17 AM ยท edited Thu, 09 January 2025 at 3:55 AM
What to do when someone else is pretending that he made an object, while it is originally made by someone else? :)
DEL ( ) posted Sat, 30 September 2000 at 9:04 AM
usually, you would download both items and do a visual and vertex comparison. if you find that they are indeed the same you post the result to the correct forum. then, you can contact the moderators and ask to have the item removed from the freestuff. If you're not sure about the comparison you could pass the info along to another person and ask them to do the same. in most cases this results in one person slinking off into a corner or if they are real people at least an apology...
JeffH ( ) posted Sat, 30 September 2000 at 1:08 PM
Is this about an item on the FreeStuff? E-mail me privately about this if needed. -Jeff H.
Mason ( ) posted Sat, 30 September 2000 at 2:58 PM
hey if its about those damn cars I posted I clearly stated in evry frickin' doco and post that I did NOT make them.
SubTen ( ) posted Sat, 30 September 2000 at 4:58 PM
i'll show you what it's all about. http://www.gwz.org/propsguild/files/Plants/page4.htm on this page you find the POTTED PLANT. and when you go to this page you will find this: http://www.3dcafe.com/models/cannabis.zip the canabis file is from 17/04/1996 the potted plant is from 04/02/2000 i did check the files ALL the leaves are the same and ALL on the same place as the ORIGINAL file...... :) the guy did ONLY made the POT and saved it in .3DS instead of the original .PRJ file.
JeffH ( ) posted Sat, 30 September 2000 at 5:18 PM
Maybe you should e-mail FastTraxx and ask him about it? -JH.
SubTen ( ) posted Sat, 30 September 2000 at 8:33 PM
well he isn't earning any money with it, but i will ask him what's up.
Artist3D ( ) posted Thu, 05 October 2000 at 2:44 AM
That does not sound like Fasttrax.
