Mon, Feb 3, 12:44 AM CST
Forum Moderators: Staff
Subject: problem about bend
smalll ( ) posted Sun, 02 May 2004 at 2:19 AM · edited Sat, 01 February 2025 at 3:07 AM
Hi, everyone. I'm korean. (Republic of Korea) So, my english is poor. I'm sorry. I'm just beginner of poser. I make box arm. I want to bend it smooth. But it is not. How can I bend it smoothly? You can download my file. http://www.smalll.x-y.net/etc/Runtime.zip Preview image is here. http://www.smalll.x-y.net/etc/SNAG-0000.jpg Please help me...
SAMS3D ( ) posted Sun, 02 May 2004 at 5:14 AM
Try turning the bend off on all parts. Sharen
smalll ( ) posted Sun, 02 May 2004 at 6:52 AM
First, Thank for your reply. I tried to bend off. But, the result of bending off is not smooth. Please tell me more..
mateo_sancarlos ( ) posted Sun, 02 May 2004 at 1:51 PM
Image 02 is smooth; it has bending applied. Create labelled drawings of:
  1. desired image
  2. image that is wrong
lesbentley ( ) posted Mon, 03 May 2004 at 5:25 AM
I think the problem here might be the mesh its self, and perhaps also in the UV mapping. As I understsnd it (and I don't understand it very well) an object can only bend along seams in the mesh the more seams the smoother the bending. See the comparison between your figure and a Poser box prop when a magnet is applied, the boxprop has more places where it can bend.
I think whether the vertices are split or welded may also have an effect on how the object bends, I think welded vertices will will give a smother bend.
I an no expert on any of this, but hopefully someone with more knowledge on this subject will either confirm or deny what I have said above.
lesbentley ( ) posted Mon, 03 May 2004 at 6:03 AM
The way an object bends is also controled be the Joint Paramiters. The graphic above showes a figure that was made out of two Poser box props. It demonstrates how using the Jount Editor can change the way the figure bends.
smalll ( ) posted Mon, 03 May 2004 at 5:11 PM
Thanks to lesbentley! It is my a purpose. You give me great help. It'll come in pretty handy to me. Thank you very much.
