There is no one particular dia. Most of them will be required to make Victoria look like someone else. I think, in your case, it would be a good idea to add all injections for V3 and play with them to see their effect. once you have an understaing what each injection does you should be able to attempt a clone project.
Attached Link: http://groups.yahoo.com/group/3d_celebrities/
I would suggest you start with the eyes and nose, that is the most memorable area of a face. Then work out to the cheekbones and down to the mouth. Working with default morphs is ok to start with, but eventually you'll need to work with magnets or an outside app to create new morphs. Theres a yahoo group dedicated to this subject, give it a look if you need help or advice.Do the morphs the same way you would draw the face on paper: start with the overall head shape (long scandinavian or flatter oriental... egg, heart, oval, round, etc.) then do cheekbones and foreheads. Finally get to the small niggly bits like curve of the lips and flare of the nostrils and bagginess of the eyelids. It makes absolutely no sense to spend hours getting the nose flare and tilt just right only to widen the head and lose everything, or to lengthen the head and have your eyesockets with neatly-shaped lower lids go all to bits. Some morphs are exceedingly precise such as just the tip of the earlobe. Others will affect much broader areas, such as a jawline morph which also shifts the chin and pulls the earlobe. You need to get comfortable with not just the target, but the area of collateral damage. ;^) Finally, do not be afraid to use morphs in reverse! Push as well as pull to get the mesh where you want it. Carolly
hi... im still learn poser , and see V3 is nice 3d female model , and now i want to clone someone face ( i know thats not easy to do even need other subsurface application to get close enough clone ) I need to know by expert ( and experience i think.. )here which part of face i should to edit first , to make V3 like someone i want , (since V3 come with many dial ) thankz for read and give info
