More than likely you need to zero out all the face MTs before applying the next one. I had similar results with a face expression pack I got for V3. The expression pose didn't conatin all the zero settings for all the dials, only the dials that were not zero. So I have to run a special zero-all face expression before applying an expression. This is probably what's happening to you. Your face dials are adding together and not being zeroed out. Try making sure they are all zero before applying the next face setup.
Mason, thanks for the reply... however.. the face morphs are INJ's from, the V3 Morph Expansion pack from Daz. Each "face" is a setting, i.e., AlienHdMale1 (set at 1), AlienHdMale2 (set at 1) etc.. etc.. there are no other dials active. These settings are then saved as a new CR2 then used with the morph utility that I purchased. I am attempting some other work arounds to see if I can get it to work... I have also sent a message to the vendor of the reply to seek assistance... but have not yet had a reply.
I have that utility, but I haven't tried it (to be honest I forgot I had it LOL) I'll give it a try when I get home.
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=25317
Dave, if it's the same one as the one i've got (and I think it is) it's this oneFREEBIES! | My Gallery | My Store | My FB | Tumblr |
Lee, all posted images are Mikes. Are you having the same problems with V3s too ? Please, be sure that u are using the original M3 object file, this utility is very dependent of vertices order. Try to reinstall M3 and transfer the morphs again. If the problem persists, please, tell me, it's the first time that somebody reports a bug, i'm excited... :)
I use this tool, and it works fine.This is from the utility description page :
Limitations:
-Input file type : .CR2 ;
-Output file type : .OBJ ;
-only the head part of the morph will be tranferred.
As you can see, the neck part is not transfered.
Lee, when u reinstalled the daz char u solved most of your problems. But we still having a problem : Some V3/M3 head injections affects two body patrs, head and neck. HMT tools will only transfer the head part. This is not really a problem with most of the morphs,but the alien morph has an extreme narrow head base. The neck's top is not affercted, so we have this ugly joint. I'm on a work travel now, when i back to my office i will produce a 'quick and dirty' patch to solve this detail, and i will send it to u. Latter i will integrate it to the HMT tools, update and mail all buyer. Give me up to 10 days. Thanks
Attached Link: http://www.renderosity.com/homepage.ez?Who=mmogul
![file_108000.jpg](https://live.cdn.renderosity.com/forum/threads/1768568/file_108000.jpg)
I just purchased the utility packs and am posting images of some results to hopefully get some assistance on what I have done wrong.
