Fri, Jan 24, 10:30 AM CST
Forum Moderators: Staff
Subject: How can I make line?
smalll ( ) posted Thu, 06 May 2004 at 7:38 AM · edited Sun, 12 January 2025 at 10:48 AM
Hello! I have a question. I can make bone. (the image is about 'setup') but, I can't make line. I don't know it's name elactly. I'm sorry. I want to make the line. Please help me... Please...
lesbentley ( ) posted Thu, 06 May 2004 at 6:51 PM
Small, I think that the picture in your post comes from Pro Pack or Poser 5, I mostly use use Poser 4, which does not provide this graphic display of the "bones". But back here in the stone age I think that this line represents a parent/child relationship between actors (body parts). In a cr2 this relationship is defined in the 'figure' section of the cr2, and would look look somthing like the graphic above (where the blue line represents data that has left out for reasons of space).
As to how you create this parent/child relationship, it could be set up in the PHI file, or you could enter it by hand in the cr2 using a text editor (there may be other ways that I haven't thought of).
nruddock ( ) posted Thu, 06 May 2004 at 8:56 PM
The line will appear when you add bones in the following way. Start with any two bones, then select the second and add a third, click to start the bone away from the junction of the first two. When you release the mouse the line will appear. You can now also drag the second bone away from the first.
smalll ( ) posted Fri, 07 May 2004 at 12:53 AM
You guys are very kind. Thank you very much. Your explain are a great help to me! Thank lesbentley and nruddock !!!
