Save the object using File/Export... Wavefront OBJ Select single frame Check the items to include. Name the file Next I select the "include existing groups in polygon groups" option I then open the new OBJ file in a text editor and ensure that the groups are named to match the Poser body naming convention. Now open the catsuit CR2 in the text editor and change the figureResFile lines to point to the new object. There are two lines, and the new object must be under the Geometries folder. Save with a new name. Now click on this new figure in the Library and your clothes will appear. An alternative route is to construct a hierachy file and bring the figure in that way. Next check that the figure conformes correctly, editing the Joint Parameters to make any alterations. Thats about the sum of it :)
