Tue, Feb 18, 1:08 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: Ockham's Exploder - split vertices problem.
SamTherapy ( ) posted Sat, 08 May 2004 at 10:11 AM · edited Tue, 18 February 2025 at 9:54 AM
The Exploder works just fine but for some reason, UV mapper isn't splitting the vertices of V3. I must be doing something wrong but for the life of me I dunno what. I start UV Mapper Pro, bring in V3 then select Tools-Vertices-Split. Save the model out again under a different file name. I created a new CR2 which points to the new model, ran the Python script and created a FBM after. When I dial up the Explode value, the model just balloons up, as Ockham said it would if Split Vertices wasn't applied first. So, what am I missing here? Please help.
ockham ( ) posted Sat, 08 May 2004 at 11:01 AM
When you look at the model, can you tell that the verts are truly split? For reference, here's what Default Casual Posette looks like with split verts. It's obvious, to say the least....
My python page
My ShareCG freebies
SamTherapy ( ) posted Sat, 08 May 2004 at 11:05 AM
Nope, they don't look split at all. I knew to expect it to look like your pic above. That's the thing, I can't work out why V3 isn't splitting, unless there's a problem with UVM Pro, or I'm doing something stupid.
ockham ( ) posted Sat, 08 May 2004 at 11:08 AM
Well, I can't help with UVM pro. I only use the free version. One other thing: the Vicky CR2 has two figureResFile lines. Did you change the file in both?
My python page
My ShareCG freebies
SamTherapy ( ) posted Sat, 08 May 2004 at 11:16 AM
Yep, I did. I'll have a go with the free version of UVM and see what happens there. I know UVM Pro doesn't like texture files above 1000 x 1000, so I wonder if it's not happy with models above a certain size when it comes to some of its functions.
SAMS3D ( ) posted Sat, 08 May 2004 at 3:22 PM
don't forget to delete the .rsr that is in the geometries folder, that may be the problem...it is the old one so delete that one. .rsr in geometries folder. Sharen
SamTherapy ( ) posted Sun, 09 May 2004 at 7:08 AM
No rsr files, Sharen. I'm using P5. Anyhow, it seems to be a UVM Pro issue. It works fine with the free version. Exploding Vicky here we come! :)
ockham ( ) posted Sun, 09 May 2004 at 2:44 PM
Yay! I'd love to see Vicky get banged ... or rather, ka-boomed.
My python page
My ShareCG freebies
SamTherapy ( ) posted Sun, 09 May 2004 at 2:58 PM
Hehe.
ockham ( ) posted Sun, 09 May 2004 at 4:11 PM
Incidentally, maybe you should let Steve Cox know about the splitting problem. He's clearly an excellent programmer, and this has to be a solvable problem.
My python page
My ShareCG freebies
SamTherapy ( ) posted Sun, 09 May 2004 at 4:25 PM
Good point, I'll mail the gent.
JohnRender ( ) posted Mon, 10 May 2004 at 1:25 PM
What splitting angle are you using? If the verticies are below a certain degree, they won't split. You may have to go with UV Mapper Pro and set the angle to something large (89.5 degrees) to see an effect.
