Tue, Jan 21, 2:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Poser 5 sr4 and Background color
shogakusha ( ) posted Mon, 10 May 2004 at 9:24 PM ยท edited Tue, 21 January 2025 at 2:28 AM
Has anyone else had a problem changing their background color in Poser 5? I know I could do this once upon a time. I have tried the color dots on the edge of the display window, Display/COlors from the menu and even the Material room. No luck. Not only could I not change colors, I cannot put in a background picture! What's up with that? Thanks, Shogakusha
uli_k ( ) posted Mon, 10 May 2004 at 9:42 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1676872
Hi Shogakusha, maybe my post in this thread can help you: http://www.renderosity.com/messages.ez?Form.ShowMessage=1676872
shogakusha ( ) posted Tue, 11 May 2004 at 7:29 AM
Thanks Uli_k! I will try that. I noticed the extraneous nodes, but ignored them since they were disconnected and so should have no effect.
pigfish9 ( ) posted Thu, 27 May 2004 at 2:56 PM
Try the link again. I forgot that the URL field automatically puts the http:// in for you. I usually just copy and past the URL form the address bar and I forgot to delete it from the end. Just in case it still doesn't work, here is uli_k's response: "Material Room ------------- - Corrected an erroneous condition where multiple, disconnected nodes were added to the background color node. As a result, the background color was not editable any more. This problem is fixed in SR4. However, if you still happen to have files where this condition is present, there are a couple simple steps you should take to correct them: 1. Open the problematic file 2. Go to the material room 3. From object menu select background. You'll recognize that there are duplicated nodes. 4. Select and cut/delete all duplicated nodes except for the "BG Color" node that was originally connected to the Background root node. 5. Save the scene. In case you have set to open new documents with your preferred state, the problem still will reproduce in files created by File->New. Please repeat the process described above after creating a new file and set the preferred state again. "
shogakusha ( ) posted Mon, 31 May 2004 at 9:14 PM
THanks all. I have this squared away now and working fine!
