Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1676872
Hi Shogakusha, maybe my post in this thread can help you: http://www.renderosity.com/messages.ez?Form.ShowMessage=1676872Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1676872
Try the link again. I forgot that the URL field automatically puts the http:// in for you. I usually just copy and past the URL form the address bar and I forgot to delete it from the end. Just in case it still doesn't work, here is uli_k's response: "Material Room ------------- - Corrected an erroneous condition where multiple, disconnected nodes were added to the background color node. As a result, the background color was not editable any more. This problem is fixed in SR4. However, if you still happen to have files where this condition is present, there are a couple simple steps you should take to correct them: 1. Open the problematic file 2. Go to the material room 3. From object menu select background. You'll recognize that there are duplicated nodes. 4. Select and cut/delete all duplicated nodes except for the "BG Color" node that was originally connected to the Background root node. 5. Save the scene. In case you have set to open new documents with your preferred state, the problem still will reproduce in files created by File->New. Please repeat the process described above after creating a new file and set the preferred state again. "This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Has anyone else had a problem changing their background color in Poser 5? I know I could do this once upon a time. I have tried the color dots on the edge of the display window, Display/COlors from the menu and even the Material room. No luck. Not only could I not change colors, I cannot put in a background picture! What's up with that? Thanks, Shogakusha
