Photoshop F.A.Q (Last Updated: 2025 Feb 11 11:38 am)
make a duplicate layer and adjust the LEVELS (Ctrl+L) then change the "blend mode" to Darken. Erase the right side of this layer to allow the underlying layer to show through.
Make another duplicate of the Background Layer and this time adjust the CURVES (Ctrl+M) Erase part of the right side again and set this "blend mode" to Hard Light.
Duplicate the original Background layer again and set this "blend mode" to Soft Light...
hope it points you in the right direction...
retrocity
play around with the sharpen and sharpen edges filter (in the filters menu) to see if you can pull more of the child's features...
hope this helps,
retrocity
With constant software upgrades, the only difference between a "newbie" and an "expert" is six months ;)
i know there'll be some things in CS that i'll have to learn when i upgrade (i'm holding out for the company to pay first ;) )
any questions, just pop in and ask... we're always open 24-7 (sometimes in a row!)
retrocity
One good trick to control good contrast on B/W shots is to covert to Lab color, select the Lightness channel, then convert to Grayscale. Ignore the other channels. Once in grayscale, duplicate the layer and set to multiply. From there you can adjust the top layer opacity. If you want to filter out set areas, create two versions, one normalising the overexposed areas, ond one normal one and history brush between the two.
Attached Link: http://people.delphiforums.com/JAXOMSTEVE/Photo/Eli-n-John.jpg
Is it possible to fix an image like this old one of my grand father with the glare in Photoshop 7? If so, how do I go about doing it?
