Is it the princess dress from Motsura? And is it UVMapped? If it isn't UVMapped you can't make a texturemap stay on it, but you can colour it with the paintbucket tool.
I don't know who made the dress, it came from Daz. And it is not UVmapped. I used the UV mapper to create a texture map which looks exactly like other maps I've seen, but the dress won't accept it. I know I can color it with the paintbucket tool but I'd like to apply some texture to it, if possible. France
France, Proud Owner of
KCTC Freebies
You made the UV map, fine. Now save the template and the model, give it a different name than the original. Now open up the clothing cr2 and change the two resfigure line to reflect the name of the new obj. Save under different name. When you open Poser you should have the shrugging man in you libraries, no problem, click on it to bring in the new clothing,apply the texture, it may look horrible depending on how it was mapped. From now on it's trial and error on getting the texture correct. Look for texturing tuts, thay explaine this in more depth and detail. Happy texturing :)
Attached Link: http://www.fallencity.net/tut-geep/index.php
You can also create surface material groups for your prop/figure inside Poser itself with the grouping tool. As always, Dr. Geep has a good tutorial on this. UnzippedI must say that if you've got the dress from Daz it sounds highly improbable that it isn't allready UVmapped. What dress is it? And are there really no textures included with it when you get it?
Well I think I got it in the free section of Daz but it is Motsura Koshini princess dress (two parts, blouse and skirt). Then again, maybe I didn't get it from Daz. I bought and downloaded so many things for Poser that... ;o) France
KCTC Freebies
THANK YOU SO MUCH for this URL. I've been searching for tutorials ever since I got Poser and I never saw that page. I'll dl everything and get going. France
KCTC Freebies
Don't thank me, thank firstly Dr. Geep for writing the best Poser tutorials there are, and the folks at fallencity.net for hosting. I'm just passing on info others around here were good enough to point me at. As I've said before - those tutorials merit a permanent link at the top of the Poser forum here. Maybe it'll happen some day. Unzipped
I agree that there should be more publicity about this. Like I said earlier, I searched for tutorials but so far, I hadn't found any "good" ones for beginners. France
KCTC Freebies
KCTC Freebies
Hello, I'd like to know how I can apply a texture to a piece of clothing that has only an obj file. I figured out how to create a texture map for it but I can't apply it. My test clothing is Koshini's princess dress. I went into the material room and connected the texture to the two first values but it doesn't work. Must be missing something... Thanks. France
KCTC Freebies
