What's the ground plane you're using? I've never yet managed to cast a shadow on to Poser's own ground plane. Have you tried placing a flat square or a box below the figure instead, and seeing if you can cast shadows onto that? And have you made sure the figure is 'dropped to floor' (Ctrl + D with the figure selected is a good short-cut). Sounds silly, but I once managed to pose a figure way above the floor that looked okay in the main camera view, and couldn't figure out the lack of shadows until I checked a different view.
Message edited on: 05/20/2004 09:59
Message edited on: 05/20/2004 10:01
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=28431
Richabri's new Studio set has amazing lights with terrific shadows and a photo studio backdrop with it yo cast shadows onto. I am totally impressed with how it renders shadows. cheerio lululeeTotoro3D, the image you posted looks to me like an unrendered Texture Shaded preview, Poser only gives you shadows in a rendered image. Also select your main light source and check the "Shadow" dial (usually set to 1.000), try increasing this value, if it's an infinite light you will have to double click on the dial and set the "Max Limit" to a higher number (say 9.000). If none of the above sugestions work, save a light set to the Lights pallet, make a copy and give it a ".txt" file extention, post it to this thread as an attachment. We may be able to spot a problem, or at least eliminate some possibilities.
Hi, its a rendered image of course, I just took away the texture map from Victoria to speed up rendering speed... BUT, lesbentley, your advise about changing certain light dials produced a shadow in my latest render. I am so happy now. Thank you so much. And thank you to everyone else too who wanted to help me. :)))
No idea why I can't cast a shadow on the ground plane when I can on other objects, Marque. I went and tried it in Poser 5 (never tried casting shadows on the ground plane in that) and it wasn't a problem, so maybe it's just a bug in my particular installation of P4. Or maybe I'm doing something wrong, but I've never considered it a particular problem for the way I'm using Poser. =^} Glad you've got things working now, Totoro!
![file_110024.jpg](https://live.cdn.renderosity.com/forum/threads/1788466/file_110024.jpg)
Reading through the forums trying to find help for my problem, I could see many people have problems getting the desired shadow in their renders... but I feel even more miserable, I don't get ANY shadow at all @.@ Please look at the attached image. The ligth I marked is an infinite light. "Shadows" is enabled. In the render options "cast shadows" is enabled too. I even tried with both Firefly and Poser4 Render, I tried changing the floor prop, I tried changing the position of the global light, I tried using a single Spot even using the shadow cameras, playing around with the x-rotation to be sure a shadow would be casted on the floor. I even tried a different floor prop and tried cast shadows on and of for the floors... Vicki itself does not seem to have a "cast shadow" for the whole body but checking several body parts "cast shadows" is enabled too. But as you see, there is no shadow whatsoever at all... what am I doing wrong???
