Thu, Dec 26, 12:05 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: SDK discussion part 1
Nicholas86 ( ) posted Fri, 21 May 2004 at 8:04 PM · edited Sat, 03 August 2024 at 9:18 AM
Ok. I think the obvious first step to working with the SDK is the software. What does and doesn't work? I know that Codewarrior is recommended, as well as Visual? But what versions work, and what versions don't? And is there a way of using an older version and still coding plugins? Brian
mdesmarais ( ) posted Fri, 21 May 2004 at 10:17 PM
Under windows, Visual C++ 6.0 and up should work. All editions. No idea if older versions would work. Markd
bikermouse ( ) posted Sat, 22 May 2004 at 12:28 AM
I still haven't dug the SDK out again to look at it but from what I remember I successfully compiled an example for C2 in MSVC6 some time ago. I think it came with the SDK. I don't know how any other compiler works but I used to program with BC4.5 when I was looking at DX7 and got that to work with that but looking back on it I don't think it was worth the extra time and effort as all the info I had there was for MSVC. In both cases I think Microsoft will do you best if you can get hold of it which is too bad in my case because I used to love working with Borland. - TJ
