Thu, Dec 26, 12:23 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: What does Optimize Shader do?
kaom ( ) posted Thu, 20 May 2004 at 11:25 PM · edited Wed, 25 December 2024 at 11:43 PM
In the texture room, there is a menu choice of Optimize Sheader.. What exactly does this do? I have never even noticed it before. Is it essential to do when editing shadrs?
thanks
kaom
Message edited on: 05/20/2004 23:30
sailor_ed ( ) posted Fri, 21 May 2004 at 6:52 AM
I never use it. I think it will clear up inconsistancies in your shader tree. But C usually lets you know in other ways if your shader is not correct. (error messages and such) Ed
kaom ( ) posted Fri, 21 May 2004 at 2:05 PM
Thanks, I've been trying to figure out what it did, but couldn't notice a difference when I clicked it.. thanks' kaom
mdesmarais ( ) posted Fri, 21 May 2004 at 2:53 PM
Just played with it a little- I don't know about pointing out errors, but it does thses things-- 1) If you have a value slider set to 0, it removes it completely 2) If you have a color set in a channel that uses a value (refraction, bump, shininess) it replaces it with a value slider set to the appropriate amount. 3) It collapses unused branches- if you have an add with an empty operand, it removes the add and moves up the one operand you have. All these changes would save time when rendering. I think Optimize trys to make your shader as simple as it can. Cool! I'll have to start using this function! Thanks for pointing it out! Markd
sailor_ed ( ) posted Sat, 22 May 2004 at 6:43 AM
I stand corrected on "error messages" what I should have said was "crashes". :-) Mdesmarais has given a clear and accurate report! Thanks ED
